new project
stallings.sean said:
Unfortunatly it looks like your on the other corner from me. Im north of Youngstown and East of Cleveland. What kind of parts do you have?
:lol: Google said Windsor was down by me :roll: :lol: I got all kinds of different parts: a 78 Calais header panel (same as a 79 H/O), couple aluminum hoods, front and rear swaybars, a console, aftermarket floor shifter, Olds Rally wheels (14" and 15"). Various different stuff from different model cars.
I got friends up around Cleveland.
Gregg
dan2286 said:
Do you have any of the A/C parts left?
What AC parts are you looking for? I dont have the underhood piece because I sorta smashed that taking it out but most of the other things I have, all the vents are in good, I have the vent control, heater core, I am not sure of the condenser. Let me know what your interested in and Ill get you a pic.
I really need the harness and the main duct piece that is under the dash.
Give me 30 min, Ill get you a photo. Do you need the dash vent controls too? I was going to keep those just to fill the space but I dont mind getting a piece of plastic to fill that in.
Gregg
are the hoods in good shape?
hows the console looking? Do you have the bucket seats too?
Do you have a dash or rear window trim, or interior panels, or rain rails? I removed my vinyl roof and the trim to go with so I have a split rain rail now and looking for a full lenght piece. Do you have the B pillar trim too?
Do you have doors in decent shape? Mine look pretty hit up on the bottom lip.
what are you looking for price wise?
Dan2286,
Here is everything under the dash, Is the second pic what you need or the piece above it in the first pic too?
PM me.
Im out of town starting friday for a week just an FYI.
veltboy314 said:
Post pics of what you need. I probably have it
Not sure if the question is directed at me or not but I need:
both doors, trim not needed.
center console
dash
rear interior panels, b pillar and rear door panel.
rain rails
b pillar trim.
so getting more work done on my car. I have a few project going on at the same time. I have the interior out and I was really surprised at the condition of the interior, the floors are in great shape. The interior panels are a little sun rotted but I plan on getting new ones or fiberglassing over the ones I already have. The seats are in really good shape too but I am going to try to do a 4 bucket set up with a custom console that Ill build. I may get rid of the seats when that is all done but for the time being they will stick around.
I have the brakes completely disassembled at the moment, they need a full work through so Ill put new brake lines on from the master cylinder to the rear drums, get new calipers, rotors, drums, brake pads/shoes, and master cylinder. The whole shebang. I figure they arent that expensive so Ill just replace what I have rather than trying to clean up what is already there. After sitting for about 6 years Im sure there is some build up in the calipers and master cylinder.
I noticed there was a small leak in the corner of my head and intake manifold. The leak was not oil so I assume its coolant. I wasnt sure if it was the intake gasket or the head gasket but when I pulled a plug out and ran the car I didnt get any moisture out of the cylinder closest to the leak. I took the intake and heads off to find that the head gasket was fine and the intake gasket was sh*t but better safe than sorry. Ive got the gasket set on the way (no one sells a gasket set or anything really for a 260) and then Ill put it all back together. I will probably send the heads out to get a run through and make sure everything is fine with them before putting them back on.
Here are some pics of the engine. Im not sure what is going on with the rear cylinder on the drivers side. You will notice its not black like the others so I dont know if the spark plug wasnt in well or not functioning correctly. What do you think, major problem or not really? It looks like all the valves seal up well against the head and there are no cracks in the head or block and the piston looks in fine shape, no sidewall gouges or anything like that.
Thanks.
