Hopefully someone out there can point me in the right direction.
Started my first project it's an 87 Monte Carlo SS. Stock 305 engine, q-jet carb, non stock air cleaner housing, custom flowmaster true dual exhaust (already on car when bought) moderate front end body damage, aprox. 139,000 miles.
I have already finished majority of the body work. entire nose/headlight, pass fender replacement. Almost rust free body. I'm not trying to build a street machine(yet, planning on swapping the engine when i can afford it) i'm just trying to get her reliable and legal (emissions and rusted floor boards didn't pass)
So here is the problem she starts up fine every time, but once fired up idles high around 2500-2800. After warmed up and put in gear (automatic) rpms drop to 500-700. Usually sputters then after 30-40 seconds stalls. Also stalls whenever coming to a stop. Checked the carb and my choke doesn't seem to move at any point during cold startup and normal running temp. Also checked all my plugs and wires all good.
Should i rebuild/replace the carb or what else could this be?
