On heat you'll get 80% of the air flow to the floor & the other 20% to the defroster. On defrost it'll be the other way around. Vent will get simular 80% center vents/20% floor. System defult per how the Astro Ventilation functions is the floor & defrost vents has equal air floor when the function lever is OFF (kind of a safety feature incase somethimg isn't working on the vacuum side so there is some heat flowing, poorly, in the cold weather). Dash center vents only work when in VENT & all A/C modes. Outer vents are A/C modes only. Floor vents will be flowing regardless of the mode, just amount of flow depens on which mode is selected.
