Haven't assembled a Buick motor in a while, but on the ones I've done, I've always needed the Vaseline to get oil pressure. Also, IIRC, the rotation was CCW, so you need a heavy duty reversible drill to get some pressure generated.
Did you buy the pump package with the longer gears and the spacer? I consider that a must-have with a Buick. As mentioned before, the aluminum housing wears, increasing the clearance and limiting pressure output. The longer gears are a band-aid fix, but the only solution outside of a new front cover. Unfortunately, many of the fine benefits of a Buick V8 are offset by a horrible oiling system.
Bill
Bill
