Cloyes timing gear on the cam nothing else. Lock plate on gear. Can button I think is steel. Its made onto the cover posted above
Good catch there forgot all about that. If you dont have one dont run it until you do. I used the comp cams billet set with roller thrust bearing. You are grinding the block away otherwise.crotchss said:Just out of curiosity do you have a thrust bearing or some sort of thrust washer behind the cam gear, between it and the block? Also what is the cam button made of Nylon, aluminum, or roller? And where the button hits the back of the cover, is this aluminum or does it have a steal insert?
Yes. With a roller cam it tends to walk in and out of the block. Unlike a flat tappit where the cam lobes are machined to push the cam inward. The cam button pushes back and by doing so it jams the cam gear into. The block. Thats why endplay on the cam is crutual.mebe007 said:Really? Is this just because of the roller can? So I need to pull the can gear and put in a thrust bearing?
