notching factory crossmember
81_2dr_bu
179
mass
was thinking of having it notched for dual exhaust was gonna install it and mark where it needs to be notched then remove it cut section out the bring to be welded just not sure if after welding if it will mount in properly or would it be best to notch the install then weld i could tac it with my wire feed welder then bring to a welder thanks for your help
axisg
2,685
2,357
YYZ
I seen a freind of mine roughly mark his placement of the exhaust, notched it 4" with a ginder, then welded in a section of 4" U-Channel and cut the ends back off flush with the crossmember. Looks really neat and almost factory. Did it all with a 4.5" grinder and a stick welder
maliburacinfreak
449
Evansville, IN
a buddy of mine has notched several this way, except he used 6" channel. leaves a little more room in case you measure it wrong. :D
slone56
81_2dr_bu said:
heres the pic not the nicest job done but came with a car i bought and it had 3" straight pipe
Forget the cross member, I like the 2 liter pepsi bottle wind mill
slone56
pontiacgp
blank
Mar 31, 2006
29,270
20,419
Kitchener, Ontario
slone...that is a nice set up but the price for some square tubing and some plate steel mig welded seems kinda pricy. It's not an overly difficult design to fabricate on your own.....
