i'm guessing its a standard part number for the case, the T5 that I had in my 87 SS came out of a 91 Camaro RS, same case number, with a 91 date code
Check the S10 bellhousing - dos it have the Chevy or ford case pattern? I have an Astro van bellhousing and T5, and believe it or not, they used a Ford-style case. Your 2000 F-body trans should also have this Ford pattern. As long as they are the same, they will bolt together. The Astro van used the larger 168-toth flywheel, but I am not sure about your S10 bellhousing. Do you know the diameter of the S10 clutch disc?
