I've been wanting to start gathering parts for a manual swap this spring in my '83 El Camino, and am wondering which way I should go. A T56 or TKO 500 would be nice but not really within my budget. I can find a T5 or NV3500 at the local scrap yard fairly cheaply.
My engine probably makes from 260 - 300ft/lbs. of torque so I will probably be at the top of the range for both transmissions. I will not be beating my car to death, but I do put a lot of mileage on it an 15mpg could definately improved upon.
I am leaning more towards the NV3500 even though it is a little less common as there is about 10 different versions of the T5, and the NV3500 is the same length as a TH350 so no cutting on the driveshaft.
I am also wondering which parts I need to add a clutch pedal and master cylinder to the firewall.
Any input would be appreciated.
