On both of mine, it was just the lines. Replaced both and was good to go. On the trucks with the radiator only coolers, those were to promote more stable temps more so than just to cool, i.e. it'd warm the oil faster in the winter.
CVPIs use a remote version of an oil to coolant heat exchanger, part of its function is to keep the oil warm during long idling periods. Its pretty much a boat oil cooler.
Some of the 3rd Gen F bodies used a really compact oil to liquid cooler that was sandwhich mounted at the oil filter. Used a coolant line from the heater hose and a block drain port. Bad thing about it is that it will not clear a mechcanical fuel pump. Guess its why it was only offered on the TPI cars. No matter type of oil cooler you use, you need one with a oil T-stant to allow it to warm up.
