Oil Pressure question- I have an 83 cutlass supreme with the olds 305 v8. Car is low milage at 65k - one family owner since new.
Car has the stock rally pack gauges in good working order. I use 10/40 valvoline max life oil.
Fully warmed up what should the oil pres be @ 800 rpm in gear, brake on - I have 28-30
Same question going down the road I have 45-47
Seems very sensitive to idle speed in gear- 650 rpm win gear will drop it to around 25
Jumps right up when brake off & driving
All above with water temp @ 195
Normal or?
Normal or?
