Oil pressure switch
hurricane
Sep 6, 2009
58
Athabasca , Alberta Canada
Hi everyone, I just finished my 383 install and now when I start the car my oil pressure gauge in the car is showing maxed out, anybody know why? It didn't do this before the swap, it was normal.
Please help me with this issue. Thanks
liquidh8
Are we taking about the stock gauge?
hurricane
Sep 6, 2009
58
Yes this is the stock gauge
jociha
279
Did you use pipe dope or pipe thread tape on the threads, if you did you need to remove it as the sensor uses the steel case as the ground, that is why it works with only one wire.
DoubleV
2,154
407
83
Medina Ohio
Maybe your 383 just has alot more oil pressure than your old engine did.
84cutty24
Jul 9, 2011
50
PHOENIX ARIZONA
Make sure you have the correct psi valve. Maybe thats why it reads too high.t :?:
hurricane
Sep 6, 2009
58
Yes I did use Teflon tape on the threads of the sensor, so it not being able to ground makes perfect sence
