Not sure if this is the right place to ask or if this has been asked before, but was wondering if anyone has recommendations / advice on motor oil. As many know I'm running a '70 350 Olds (with '72 #7a heads), that's built up a little and was wondering about the newer oils not running the same amount of ZDDP, if this would be a problem in the long run and if there was an oil that still has the previous amount of ZDDP.
So basically am asking if anyone here have any comments on what may be a good oil to use, pros / cons. I used to run Mobil in my previous two Olds, '66 Impala & truck and they seemed to run very good, with any bearing, cam/lifter failures, but have a little more invested in this one, so kind of want to protect the investment. I've heard Valvoline is a good street oil but honestly never used it. Since the car is mostly street driven (not raced) now (with a rare run down the strip), was basing oil selection on conventional, not synthetic.
Or am I reading too much into the reduction of the ZDDP?
Thanks.
Thanks.
