What pulleys and brackets do you have on that olds engine
Late 90’s chevy 4.3/5.0/5.7 brackets and pulleys, 302 ford crank pulleyWhat pulleys and brackets do you have on that olds engine
I was designing adapter bracket to do this and another guy on real olds power had the same idea so I stoped on mine and bought a set of his. I think his name is Larry but I don’t know if he still makes them or not and there way nicer than the ones I was doing myself If people on here are interested in sets we may be able to track him down on Facebook the crank pulley was the most modded thing I welded the center up turned it out to fit the olds balancer and redrilled the bolt holesIs it a bolt on and go or modifications needed?
That front passenger side port is for the distributor, there should be a threaded fitting/larger nipple at the rear base to work for the heater vac source.
