Re: Old School Meets New - Supercharged LSA into Grand Natio
Thanks. With the adjustable suspension I expect it to be competent at everything but it is definitely set up more towards handling/AutoX/road race.
It took a little dancing between the height of the jack under the car, the hoist and the tilter, but I got it in without major drama. I wanted the car as low as possible but the long legs of the hoist had to clear the front suspension bits and Ridetech brace. I put some foam on the tip of the transmission to help prevent scratches on the firewall. The only tiny blemish is where the rear coil bolt (which I should have removed) touch the fiberglass AC housing and made a little mark. Easily dealt with.
Here the progression:
You can see the Dirty Dingo adjustable engine mounts attached to the motor here. I set them most of the way forward (sets the engine rearward), mostly for header clearance but it helps the weight distribution a bit. I ended up having the move them all the way forward to engage the frame side solid mounts.
More than partway in - I should have stopped and taken 1 more photo coming over the rad support.
Leveling out some:
In with the motor mount bolts in and the driver's side Hooker cast header mocked up:
And the same on the pass side:
You can get a good sense of the clearance of headers around the front lower control arm rear attachment points. Much better than dealing with the CTS-V or F-Body factory headers which would have forced a sharp bend in the exhaust leading into the cats.
Off to play with the transmission cross-member.
Jim
Leveling out some:
Jim
