Re: Old School Meets New - Supercharged LSA into Grand Natio
Getting it back together after the firewall and removal/repaint of the inner fender liners:
Made a gasket for the TNT manual brake bracket out of FelPro gasket sheet because I didn't want to leave it unsealed but I also didn't want to put a bead of RTV on there. This was a clean option:
Holding the Wilwood master cylinder and TNT bracket in place:
Tomorrow I will swap the proportioning valve and clean off the brake lines, then get this all installed.
If you get the entire system correct, I really like manual brakes better than most American power brakes. I have a similar setup on the Grey Ghost and they are very progressive, nice distance on the pedal stroke and capable of really pulling the car down from speed. The final steps after everything is bled and ready to drive is to bed in the new pads then perform some really hard stops to ensure you get the rear proportioning valve adjusted just right - the rears should never lock up before the fronts.
Things should speed up a bit after this. The engine compartment is a lot cleaner than it was before.
Jim
Jim
