Turna are you coming over to the dark side!?View attachment 92938
A/C Delco or ngk btw I don't remember the # off hand
Clutch where you been?!!??!!??!!?
AC Delco, or NGK as well. What compression you running? Points, HEI, or MSD Ignition?
.......doesn't matterStock non CCC 307 for now DUI HEI
That’s one awesome Olds engine you have there. After seeing that engine, I guess all of the Olds powered stuff that I’ve owned is just a bunch of old stuff bolted together - haHere ya go Turna, I remembered to have a look for ya.
This is what I’m running...
....in this:
D.
NGK XR45 or XR5. But you have the long reach plugs, since you have a 307 swirl port, should be FR45.
It needs more shiny to go with that bite...Thanks. I can tell ya, and as you probably already know, it ain’t easy making an Olds motor look pretty.
This ones got some bite to back up the looks tho...
