Olds motor mounts
I'll try and get or make a picture for you tomorrow, i can't remember specifically which ones i used.
Depends on what trans you had in the car before? I'm using the stock cross member and the mount that came with my TH350
Wait, olds powered f bodies used chevy frame mounts and a b*st*rd motor mount to install them. Couldnt you just get 77-9 olds powered t/a mounts and use your factory chevy frame mounts? Pretty sure that works.
Thanks man I appreciate it I almost gave up on that wh*re. I took the engine n the brackets off more than 3 times hopefully ican get this thing set n running .
Marcar i tried, they are different. To see the differences you'll have to have the parts beside one another. FIrst the mounting holes are slightly off from the T/A to the SBC mounts, won't line up and you'd have to oblong them. Second the rubber bushings have a difference in the steel inserts/ height. You'd have to use the 403 brackets with the mounts from the T/A or they just won't fit together.
Trust me, i tried everything and the only options is to buy the right hardware to get the job done.
I got the brackets from the 307 n I got the motor mounts from the trans am
My car had the 3.8 buick
Yeah I got those brackets n I got the rubber mounts from t/a new. Do you know if the exaust will fit the manifolds from the 403
