Been powering though my list of things to address.
I started by cutting up and fitting the old exhaust.
Once I got it where it kinda fit and wasn't terrible I cut an angle in the end and welded on the v band.... Stacked the beads in the mig cheat fashion, instagram ready... Yes, my work stand for the band say is high tech...
It looks like its going to work.
I need to buzz on a hanger mount for the back but otherwise I think it will work. Its kinda more quiet now.
Then I started working on an oil pressure oddity. I have a pre-filter oil pressure sensor that shows 48 psi at hot idle and my top of engine shows 18psi....
So I had ordered a replacement Delco sensor a while ago, I threw it in thinking the crusty old OEM sensor was junk. and there was no change. SO I put a mechanical on the bottom on the pre filter side, and it checked out with 50psi. I tried a new oil filter and no dice, no change.
Due to the serious space constraints behind the intake by the oil pressure sensor and the fact that the MAP sensor is RIGHT in the way I had to get creative to swap to a known good 5V 100psi sensor....
The good sensor was no different in the reading so I took off the Earls cooler fitting and went back to my ICT Billet turbo feed fitting. This corrected the issue. I have a 5psi drop across the oil filter and 42psi hot on top of the engine.
I don't think the Earls cooler adapter was the culpret, it just seperates the oil passges to pump unfiltered oil through an oil cooler and back to the cooler... I suspect an incorrectly installed barbell.... which sucks a lot. But that will get checked next.
