Ok, got one more pair of body mount locations to replace and the chassis upgrades/ repairs are done. Which is good because the weather here is back to sucking and I am back in the garage to keep making progress.
Got the rear bracing welded out. pulled the springs out and let it sit on the frame to check clearance. It will touch the rear disks caliper bolts to the frame before it hits any of the bracing. Win.
So I got to fabricating up lower arm bracket braces. Again I just saw something on Trick Chassis' site and decided to reproduce. So begin the process.
1: Make templates.
2: Transfer to metal and cut out.
View attachment 161191View attachment 161193
3: Fit to mount brackets.
4: Tack in and add internal bracing. I added a piece of angle iron inside the brackets to add rigidity.
Since I had bought one 3/16" x 4" x 8' flat bar I just cut some slices off it to weld in instead of one long piece and bending to shape, I think it came out alright.
Got a little more clean up of the booger welds I did on the bottom and front. I think its going to work.
View attachment 161200View attachment 161199View attachment 161198
I did some calculation of the weight added with the metal I have used. Its a bit of a rough estimate but so far only 33.74lbs of metal added. Thats what will come out of the doors once I get the drivers door bar out, I think this will be a bigger upgrade than a door bar.
