If your engine has 5A heads on it already then it is not a roller motor unless someone changed them. which makes it a better starting point for modification. as for the rear unless you can find a build sheet somewhere in the car, likey places are under the rear seat inside the drivers door panel or under the headliner board, you will have to crawl under the car and on the passenger side axle tube facing twoards the front of the car there should be a code stamped such as AJ or 2BK for example. it may take some wire brushing or sanding to find it but when you do post what you find and me or someone else will be able to tell you what you have.
