What is the psi in the tires? Can you safely lower it a bit? A hard compound tire will ride stiffly too, you may need something softer.
Did you notice that he doesn't live in our country? He's from the Netherlands...no NAPA stores there.
Good answer....I'm going to have to agree with you there, Steve.they make up for no Napa stores with beautiful women....🙂
yeah thats true, i replaced the body mounts because the metal plates/shims were all gone (rubbers were all good). after replacing the mounts the car car felt slightly better during cornering but i lost a lot of comfort. the difference in that is huge. now i can feel EVERYTHING. i can even feel a bump when im driving over something like road markings. and when feeling something like that i also notice a lot of vibrations in the interior lol. (gm built quality FTW)by your first post it sounds like everything was ok even with the shocks until you changed the body mounts.
I can agree with thatthey make up for no Napa stores with beautiful women....🙂
Idk where you shop but the stock bushings are sold at napa around here anytime. Different tires with more meat might make a difference too. My tires are 275. You should certainly be able to get away w/ up to that size if your suspension is really tight. Moog springs add a little spring rate and put the car a fraction of an inch higher as well. Is it possible your steering shaft is reacting to the new tighter suspension? It might just be time to upgrade the steering shaft. If you still have the stock one it is probably struggling to keep up. On my 79mc the stock steering shaft and joint were the first thing to wear out after firming up my suspension.
