No one has mentioned the 2nd to last pic 🤣🤪
Queen units start with a K; that is a freedom M.
Patient? I don't get it....
That's what they taught us in school. Thats also what gm taught. Oh and what ford taught us. When you look at the wiring schematics, that's also true. But in reality, a waste spark coil system can have a single cylinder misfire and the cause is the coil pack. 13 years as a driveabilty tech.I know it's not (or shouldn't be) the coil because wasted spark. If the coil was bad, it should have 2 misfires, no? There are 3 coils for 6 cylinders.
Sounds like you are already halfway to getting the problem solved.I can dig it. The Taylor plug wires are only a couple years old. The #1 plug was pretty white, but the electrode and ground strap are intact. #1 is also the first injector by the rail inlet and I've had a bad injector on 3, already. It only pops up when I hammer it. It's fine if I drive like a normal person.
Ah, apparently pigs can over 100 mph👍No one has mentioned the 2nd to last pic 🤣🤪
Thing I love about this post, aside from the technical content, is how difficult, therefore rewarding, it is, to orient yourself, and understand what you're looking at as you carefully slide your gaze from the first engine compartment picture to the last one.EGR valve
View attachment 177696 View attachment 177697 View attachment 177698
I ordered some block off plates from Amazon that were too small. I poked around the webz, and nothing looked like a match. I had a pack of cheese ball, Mr. Gasket pipe plugs on the shelf, so I borrowed a tap from neighbor Jimmy and sent it. Hopefully, the check engine light stays out, as ZZP was spoda do that in their "Stage 1" tune. The reason for this is the huge crack in the EGR manifold, should be visible in the pic. I could feel hot air with my finger. Last weekend, I mashed the throttle coming out of a traffic jam. It was right at the top of 1st for a downshift, it decided that the rev limiter wasn't necessary at the time, and it let out a tink, tink, tink! Then, the CEL started sending me Morse code. It was a P301 misfire, so I figured it was the huge exhaust leak.
