That's what I meant- brain fart!That is not all they bought....🙂
http://www.performanceracing.com/news/umi-performance-acquires-pa-track
Nice talking with you. Thanks for the order!Springs are on the way!!!!!
12.846 @ 110.91
Greetings Guys; This is very interesting info, Thank you for posting this. And this is rear wheel #'s!? I believe that I had looked at your engine build a 383 w AFR heads. But didn't retain the compression #'s, intake runner size & cam specs. Could you post them again please. I didn't dyno my current engine a 406 w AFR heads 200 cc runners, 10.2 comp & 230 - 236 dur .553"- .565" cam, but from previous build put on engine dyno had guessmated this engine around 500 HP & 510 Lbs Tqu. Maybe 430 at the tires?? Anyway my ET's are usually 12.5's with best of 12.46 all around 110-111 MPH. Oh 3.42 gear, 2100 RPM stall & 3500 Lbs. And I post this info for all to see how different application's of similar engines can have similar results but yet be very different! Did I spalne myself??? I should add I love your project car & would love to get blasted on a Auto-X, hold my own on the drag strip & maybe be the more comfortable ride going to an event (say Power Tour). Thank you for sharing, Ole' BobWe finally got a chance to dyno the Green Machine.
519 hp @ 6000
536 tq @ 4100
