very nice cars, I really wanted to run a Camaro, but this metric car is what became available first, still looking for an f-body with an LT or LS-1, since we are allowed to run factory fuel injection if the car came with it, and I want rack and pinion steering
bit off topic.. so forgive me please but...
I thought I would quickly share what I did for a clutch pedal, seems there are a lot of different setups for getting a clutch pedal in a g-body, I dealt with this problem as well, of course
first I tried to mount a clutch pedal from a 95 Mitsubishi Eclipse outside of the factory bracket, which was the basic setup I found through google searches, it worked but there was a noticeable amount of play and the position was just, off somehow for me,(not to mention we mounted the master cylinder too low trying to clear the brake booster and had no leverage and bent the pedal
) so I decided to go about it another way
http://i.imgur.com/GdV8A.jpg
used a brake pedal from another g-body, cut the pad off and heated the pedal with a touch, bent it to the correct position and went to work on getting both pedals inside the factory unmodified bracket
i measured and cut the bearing housing(round tube the bolt goes through) on the top of the pedal, basically shaving little by little off until the two pedals together, were the width of one originally, the plastic bushing/metal bearing setup would no longer work (too much play for pedals so close) so I decided to do a bit of a redneck engineering solution
found a 1/2 socket that would very nearly fit through the pedal, and with lots of time sanding/grinding on the socket and pedal housings, I got the new "bearing"(AKA butchered socket) to fit as perfectly as possible, drilled the socket out so it would accept the factory bolt for the brake pedal, and bolted it all back together
http://i.imgur.com/lJnLV.jpg
pedals were too close for my liking, so I removed more of the bearing housing from the pedal on the opposite sides, thereby moving them apart and used washers to make up the difference, once its all bolted together tight and in the car, there is NO play what so ever in the pedals, has a very "machined" feel which is so much better for the brake pedal
we are also running manual brakes without a booster so the clutch master cylinder would fit under the brake master cylinder, retainer cap on the brake master cylinder, and adjustable stop keep the rod from falling away on the brake pedal, had to make a cap since all we did was remove the boost from the power brakes, seems to work just fine, I like the extra required force on the brake pedal a long with the new "no play" feel, clutch is still kind of stiff, but completely acceptable for getting on and off the track
probably would not work this way for a street car, unless you can get a clutch master cylinder that will clear the beak booster AND be high enough for mechanical leverage, trust me when you mount the clutch master cylinder near the bottom of the pedal and then try to use it... it does not work I was lifting myself out of the seat pressing the clutch, and trying to release it gently was impossible, the moment you relax your leg a little it would just throw your foot up, never would of guessed how much force was really at play here
also, we are running a hydraulic throwout bearing, so no slave cylinders needed
if anyone wants to know more I could try to help out, sadly I did not take any photos during the actual construction, I was in a bit of a rush and kind of upset that all the work I put into the first setup went to waste, not completely finished in the photos either(this turned out longer than I envisioned, oops)
