Panel bond adhesive
Duramix was bought by 3M over a decade ago, and they completely changed the product .
Sucks, 'cause Duramix was awesome...3M, not so much.
  • Sad
Reactions: Clutch and ssn696
Abs is one of the easiest plastics to glue, not being a slick or oily type plastic. If trying to glue in tabs to inside , as are cast into the fiberglass parts like 565 showed, any multi-purpose 2 part epoxy rated for abs would be fine. Don't remember part #, but home depot sells a self mixing tip epoxy made by Loctite/ Henkel ? 5000 psi rated that I used on metal & plastic mounts to hang heavy 1/2"thick glass doors.
As far as brand names from autobody stores, I found the Finishmaster stores house brand Smart to be as good as 3-m's 8115 for about 25% less cost.
Reactions: Clutch and Rktpwrd
Like this?
I'll go browse the local HomeDepot and see what I come up with...
Thanks all!
