Well, this went from simple maintenance to a problem to a mystery.
I decided to change my PCV valve. Simple enough, pull the hose, the valve comes out, put the new one in, put the hose back.
Not quite. My first clue that there was something wrong was the breather hose filter was in terrible condition, as if I had soaked it in the bottom of a used motor oil barrel.
The breather hose didn't go right to the valve cover as the manual suggests, but it goes to a plastic elbow which sits in a rubber grommet that goes in the valve cover. This did not come out easily. I pulled as hard as I could and it didn't come. Eventually I just started prying with screwdrivers until it partially came out, then I grabbed it with pliers and pulled it the rest of the way. Age and heat had made the rubber very hard.
I thought I had a problem because no PCV valve came out. I thought it had fallen through the valve cover hole. I looked around with a flashlight and felt with my fingers and didn't find it. That, combined with the extreme amount of oil and gunk on the filter leads me to think that there wasn't a PCV valve in there to begin with.
So then the mystery came. I got a new PCV valve at Pep Boys (not my favorite location but there is one about a mile away from my apartment and the Auto Zone nearby didn't have one in stock.
The new valve does not fit with the old parts. I cannot at all figure out how it would. It's too big for the breather hose and the plastic elbow and it only halfway fits through the rubber grommet.
My theories:
- That plastic elbow is not supposed to be there. The hose goes right on the narrow part of the valve and the other part of the valve fits in teh rubber grommet
- The PCV valve I bought is not the right one
- The rubber grommet and/or the plastic elbow that was in my valve cover is wrong
Anyone have any knowledge on this? The vehicle is a 1984 Regal, stock 231 V6.
My theories:
