jonnyslick said:would the 2" belltech drop spindles along with a 1" drop coil be too low you think?
Also, how does the drop spindle effect the geometry of the front end?
85 Cutlass Brougham said:I have Global West uppers for the negative roll setup, and have heard bad things about them due to bump steer issues. I am trying to mathematically figure out a way around this. Also, lowering springs take away caster, and along with it, high speed stability and on center steering feel.
Tony_SS said:Thats your best bet. Get all your parts together and do the swap once and do it right.
You know, if you want to go a cheaper route, get a set of Moog 5658's up front, a KYB shock and an SC&C stage 1 with the tall lower ball joints instead of the uppers. That will get you a 2.25-2.5" drop up front for not alot of money. Add a 36mm hollow front sway bar from an f-body and you'll have a good riding, firm handling front end. Cost would be around $650 for parts and your front end is done. With those parts you could run +5 caster, -1.5 camber and an 1/8 toe. High speed stability with tight cornering.
