For you guys whop are using a stick are you using a pilot bearing or a bushing. I use the needle bearing pilot and I have to replace it after only about 5 months use. The one before that lasted a little longer and I thought it might have been defective so I replaced it with the current needle bearing pilot. I measured the shaft to make sure the play was not excessive for a roller bearing but it still failed. I'm thinking of replacing it with this...any of you using the Jerico Roller Pilot Bearing...or should I go with a bronze bushing
