The run is not being caused by the idle speed. The idle speed is a symptom that something else is wrong. Wouldn't it make more sense to find the source of the problem and fix that??
How do you like that Chryco master with manual brakes?
I got the solenoid and bracket installed and ran a fused power wire to an un-used terminal in the fuse box,now it idles and shuts off.
View attachment 91683 View attachment 91684 View attachment 91685 View attachment 91686 View attachment 91687 View attachment 91688
The solenoid bracket took almost all day yesterday,I had to bend and twist it,as well as cut and grind it to get it in the right place.
The power wire is the big red one in the first picture.
Looking at it now,I don't really like where I ran the power wire through the firewall,so I will fix that ASAP.
Guy
Nice work Guy except the fuse needs to be at the fuse block so you protect the entire wire
By the way I will be in Nova Scotia next week
