please identify engine mount
doood
Amateur Mechanic
Sep 24, 2020
590
804
Is this welded engine mount for SBO or SBC? This is the engine bay of a 78 cutlass roller. I see low pressure fuel line, so whatever was in it was likely carbureted.
I should be able to grind that off I think.
78Delta88
1,303
1,096
SW Arizona
Same. Unknown but possible came from factory with the v6 or the 260 olds v8. Most were yanked and swapped over to Olds 350 or Chevy 350. These are DYI made for solid mount and most likely for SBC.
doood
Amateur Mechanic
Sep 24, 2020
590
804
I'm sure the car is all hacked up if somebody put in solid motor mounts. They look well made, but WTF? Solid mounts with what rear? Guy started getting rude because I was asking questions about a $2800 roller 4 hours away... prolly not going to go see it, but the car looks nice.
ELCAM
1,124
1,270
The mounts are in the chevy spot but look high, perhaps it had a late model big block with a stock oil pan that requires some kind of modifications to fit.
78Delta88
1,303
1,096
SW Arizona
Depending on where you live, 2800 might not be bad for a good roller. I wouldn't let the mounts be a show stopper. With clear title you might even be able to flip it for 5k, ... Never know ... If me I would go look at it and negotiate from there. Around me right now I have about 5 rollers possible for around 1500 but right now too many other things going on.
78Delta88
1,303
1,096
SW Arizona
I was wondering the same. The attachments look a little high. And maybe a little farther apart than small block, but hard to tell just by a photo. They do look well made so whomever created them did have skill. Summit has the plastic mock up blocks but for 400 USD I'll keep with my old 305 gutted block for mock up. The easiest would be put an empty block mounted to a trans shell and see how it fits, hood clearance, floor pan tunnel, Cross member... Etc...
