tc1959 said:
I know there many opinions out there on this subject. I just wonder with all the hundreds of wheel choices out there that will fit on our cars why bother messing with spacers at all. Personally I wouldn't want them on a daily driver. But that's just me .
Why risk the chance that something will break and damage your car. :?
Simple reason is the rim of choice is not made in the option you want or is a discontinued wheel that is no longer made anymore.
For me I run spacers on my rims for a couple simple reasons. 1st my car isn't stock so a rim built for a Gbody will not work any more. I have a Vette C4 rear end which allows me to run a lot deeper rim and must be a 16" rim(not all 16's will fit) or larger to clear brakes and hub assembly. I have 17x11 Gotti rims with 7.5" of BS. These rims are rare to start with and no longer made. It took me 4 years to find a set that was the correct size. The tires were already on the rims when I bought rims. The 335 35 17 Potenza's without the spacer(3/8") rub the frame. When I wear these tires out I will replace with 315 35 17 and then won't need the spacers.
I have to run spacers on the front because the Gbody steering setup I rub the A-arm without spacer. I am looking for narrower inner barrels so i can make my front rims narrower with less bs.
My Regal is not a DD, I would not spend the $$$ and time on my car like I have if it was a DD, but that is me. To add to that I looked for a rim made currently and honestly there isn't a single rim on the market that I liked or wasn't so over used.
Cars come from the factory with spacers and rim mfg's also sell rims with specific spacers designed to work with their rims
