This^^^ We call that stuff devils snot.Did you use the Energy Suspension lube or simular on them before installing the contol arms? They suggest coating the surfaces that contact metal to reduce the noises.
Thank you! That is good information. I didn't know that.Poly bushings squeak because they bind in multi axis rotation applications like those found in G body suspensions. Rubber bushing deflection allows for the required multi axis rotation. Rubber bushings pretty much behave like a torsion spring except the spring rate is supper low. Poly acts similar to a metal bushing that only allows for a single axis of rotation.
Rubber
vs polyurethane
Everything has been regreased. The creaking sounds aren't as bad now, but I can still hear them every now and again. It really gives my Monte Hoop-D vibes. If it doesn't go away in a week, I'm putting rubber ones back in.
I was thinking you'd done poly up front, the rears on these suck like a Fox Mustang. They have to be able to twist because they fight each other. Could do heims and/or a poor man's 3 link.
I did do poly on the front. Upper and LowerI was thinking you'd done poly up front, the rears on these suck like a Fox Mustang. They have to be able to twist because they fight each other. Could do heims and/or a poor man's 3 link.
