All great info. Thanks againAlignment issue would be my guess. I have chased this for years in the monte but I dont start tossing belts ( denting hoods, overheating, smoking AC compressors etc until north of 5500 rip m s ). The Serp belt conversion for the Alternator from an 86 Up Gbody Cutlass or S10 really helped. It still leaves the PS and AC on a V groove belt. 267 or even a 305 should be fine with the v belts
I will. AC belt is off for now. Just in time for July. ThanksAlso make sure the AC clutch didn't lock up
The main thing is finding the cause of throwing your belts and fixing it so it doesn't happen againI will. AC belt is off for now. Just in time for July. Thanks
I will get on it. Throwing a belt is not funThe main thing is finding the cause of throwing your belts and fixing it so it doesn't happen again
Sheet metal hoods hold heat in thus the increase of heat in the compartment. Thus..... belts stretch and come off the pulleys!!!!!!!!happy fourth!! Snapped fan belt
One broke, One fell off
One nowhere to be found.
Heard a bit of fan belt squeal after I replaced the new hood.
Thinking….. i replaced the cowl fiberglass hood…… for the flat steal
created excessive heat. Or ? Cheap belts !
How can I avoid this issue. Stock 267
Small block A/C
Thanks guys
Hi this is what I was thinking, but another said impossible.Sheet metal hoods hold heat in thus the increase of heat in the compartment. Thus..... belts stretch and come off the pulleys!!!!!!!!
Thanks for this info . I will work on this as soon as this holiday is over. And if I can ask you a question ? There have been some theories about my new steel hood and it’s contained heat as I just got rid of the 4” fiberglass cowl. Does the new flat hood play a role in the belts being thrown? Thanks DezWith the belts off, check all the bearings. Also you have the standard small block Chevy layout with the pancake AC, and you're running headers. The bracket that goes to number one cylinder exhaust manifold will not work with the header tube. That bracket has to be modified to work with the tube. If that bracket is not put on your AC will vibrate and it will break the mount and it will break the bolts. You'll see it from the front it'll look like the bolts are in and it'll look like the bolts are torqued, but they're not they've been broken. Check your mounting bolts to make sure that that is not the case. Also the bracket on your power steering is supposed to be flush to the block it's in between a nut and then fasten down on the stud with another nut. If I remember correctly that bracket is supposed to be flush to the block that means your power steering unit is out of the alignment.
No. Belts just wear out. During the mid 90s Saudi Arabia came here and bought all the civilian and police taxi impala and Caprice they could. All had steel hoods. The reason Saudi did that and bought Chevy is because the Caprice and Impala (A Body 77-90) didn't break down in the desert heat like the Ford LTD Crown Vic. Chevys are good with heat..Thanks for this info . I will work on this as soon as this holiday is over. And if I can ask you a question ? There have been some theories about my new steel hood and it’s contained heat as I just got rid of the 4” fiberglass cowl. Does the new flat hood play a role in the belts being thrown? Thanks Dez
