hy82e said:A question for you guys with experience with por 15.
How well does it touch up?
While I have the frame out I'm going to be attempting some notching, trimming, and bracing. Most of it can get done before I coat it and get the body, and motor back in it, but there are a couple areas that I want to wait to be sure I clear everything. So if I coat it first can I come back and work on it then re-apply the 3 step process to those areas again?
hy82e said:Anybody ever use Kbs coating products? Application process is similar to por, but claims to have moderate UV protection. Less expensive too. Another option for the OP.
hy82e said:Thanks carlola. welding would be involved so definitely bare metal. So por is resistant to its own prep chemicals? My concern was in cutting it in to the area and that the prep chemicals might strip the surrounding finish.
