Again lots of misinformation here.
You can’t use the .921 roller lifter in a 425 block, the lifter bosses aren’t tall enough to accommodate the lifter.
Secondly, it won’t take 5k more to go from 400 to 500 hp. You can make up that difference with cylinder head, cam and Carb. If you want to strengthen the bottom end at that point you should be able to do that for a grand or so.
And finally, with all due respect to Bernard Mondello, my premium head package is significantly better than his both in price AND flow.
Note; I have a 45* roller available as well. It’s an excellent street grind that should get you where you want to be.
Thanks.
Thanks.
