I Finally finished my 383 stroker swap, used the stock trans that was already in the vehicle. The trans worked perfectly fine before i ripped out the stock motor, Made absolutly no noise of any kind and didnt shake uncontrolably. I finished my swap and in the process i broke my kickdown cable and shifter cable, both have been replaced but ill explain... I broke in my engine for 20 minutes in park, everything was fine. After that i noticed if i reved my motor the car would shake uncontrollably, i would drive it around in the driveway but one day it wouldn't move, turns out the trans fluid was low so i added some and then i got it to move but didnt realize it was comming out of the kickdown cable hole, when i did notice that i replaced it and then no more leak i added a whole lot more trans fluid and now instead of shaking when i rev it its only noticable from the 2000rpm to 3000rpm range. i called the company and told them my problem and they responded with "the motors are computer balanced" so pretty much canceled out the motor... I took it for a drive and then noticed it makes like a sort of grinding noise/banging noise, kinda like an air plane turbine sorta deal. Thought it could be the exhaust but wouldn't it make more noise when your on the gas? The noise is actually louder when you get off of it. noise vanishes when speeds are less then 10mph.DOES ANYONE KNOW WHAT COULD POSSIBLY CREATE THIS PROBLEM???? or atleast any suggestions
