Thanks all for your help. I've been doing some checking with some resources that I have here. I have an '86 Grand Prix with the factory power locks in it, and I've checked it out, comparing it to the Monte. I also have the 1984 GM electrical manual for the Monte, and the '82 & newer GM G body parts manual. According to the parts book, there is a single part number for a cross car wiring harness for both the power windows & locks, which is separate from the main cross car electrical harness. There is a relay behind the kick panel on the passenger's side which is for the power locks, with 2 connectors going into it. There is also a separate flat 6 wire electrical connector behind the kick panel, which leads into the door for the power locks. The power windows have a 3 wire electrical connector that goes into the door. I've checked behind the right side of the dash on the Monte, and there is no evidence of the 6 wire connector, or the connectors that go into the relay, which leads me to believe that I'm going to need some kind of cross car harness to make this work. If anyone has any other info, I'd greatly appreciate it, thanks.
