Power Mirror Wiring
Rktpwrd
Builder of Cool Shjt
4,168
23,918
Calgary, Alberta, Canada
Hey guys
It’s not often that I get stumped and have to ask for help, but this particular one has me baffled.
I’ve installed 3rd Gen F body mirror motors in a set of Monte SS housings, and am using the matching F body mirror switch to control them.
The issue is, there are 4 wires going to each mirror for a total of 8, but there are only 6 wires out of the switch to control them. There’s actually 8, but 2 of them are power and ground, the orange and black.
I’ve made up a temporary harness to test the mirrors, the orange and black run directly to the battery. Which leaves 2 green, 2 white, one blue and one yellow to control both sides. It doesn’t seem to matter what combination of wires on each side I splice together (I figure at least 2 HAVE to be spliced per side) I can’t get the functions to operate correctly.
Have a look at the screen grabs I got from a YouTube video below that explains each wire colors function, and explain to me how it should be wired. Because I’m stymied here. I think part of the problem is because each wire is either powered or grounded depending on which direction is selected.
Thanks!
ELCAM
1,124
1,270
Upper case letters are switch terminals, lower case are motor terminals.
A - Ground
B - Light Blue to both mirrors b terminal.
C - Yellow to both mirrors d terminal.
D - White wire to terminal a Left mirror only.
E - Light green to terminal c left mirror only.
F - Brown/ White to terminal c right mirror only.
G - Red /White to terminal a Right mirror only.
H - +12V
Rktpwrd
4,168
23,918
F - Brown White to terminal c right mirror only.
G - Red White to a terminal Right mirror only.
Splice a brown and a white together?
There are no red wires…
ELCAM
1,124
1,270
That's brown with white stripe wire no splicing.
Data is from 1988 camaro colors might be different for different years, can you read the terminal letters on the switch?
Rktpwrd
4,168
23,918
Thanks for the clarification.
The switch plug is original GM, so it most likely will have them, but I will have to confirm a bit later. Each mirror plug has terminal letters on them that are legible for sure.
UC645
1,083
3,072
Kittanning, Pa
Based on your pinouts I’m *assuming* the C4 Vette mirrors are wired the same as the Camaros, on mine, I have both the white wires spliced together on the driver’s side harness. I’m unable to get to the passenger at the moment though.
But from my old notes, the wiring should be the same, even the colors match.
My old notes are in pagrunt’s thread:
Rktpwrd
4,168
23,918
A - Ground
H - +12V
Unfortunately neither of these combinations are correct. I tried both tonight. After extensive testing of all the circuits and their functions, this is what I’ve determined:
The closest I can get it to being correct is how I currently have it wired:
Orange (terminal A on switch) to +12V
Black (terminal B on switch) to ground
Both yellows (terminal C on switch, and terminals D on the mirrors) spliced together.
Both blues (terminal D on switch, and terminals A on the mirrors) spliced together.
Green (terminal E on switch) to terminal C on left mirror
White (terminal F on switch) to terminal B on left mirror
Green (terminal G on switch) to terminal C on right mirror
White (terminal H on switch) to terminal B on right mirror
This results in the left and right sides actuating the proper sides, but the functions are 90 degrees off on the switch. If I put the selector to the left mirror,I have to physically turn the switch 90 degrees to the right to get the functions to move in the correct directions.
The opposite occurs with the right mirror, I have to turn the switch 90 degrees to the left to get the functions to move in the proper directions. If I attempt to wire the switch and mirrors color to color, it’s way out of whack. That’s how I tried configuring it initially. The up function for the right mirror would result in a left movement on the right mirror and all sorts of other weird reactions.
Help, how do I fix this!?!? I’m closer than I was last night, but it’s obviously still not right.
ELCAM
1,124
1,270
Try switching D for A at the motor connectors.
Rktpwrd
4,168
23,918
mclellan83
4,270
9,483
Pgh, PA
Hopefully will be feeling your pain soon, so following to see how all this works out
