Power steering gearbox fitting
houston_t
146
108
Metro Detroit
Hey I am looking for a fitting to go in my gearbox pressure side ( inverted flare ) that will allow me to use the o-ring type hose off of my 2001 LS1 engine im swapping in, does anyone know of such a fitting ?
I have searched but I only found the fitting that goes into the p.s. pump to allow you to use the original pressure line, I want to do the opposite and use the new pressure line.
Thanks.
81cutlass
4,649
13,565
Western MN
The 80+ steering gearboxes are saginaw O ring style and anything newer should swap in. Do you have a 78/79?
Going from male saginaw to female inv flare might be tough. It might exist but...
Pressure side hose, correct?
houston_t
146
108
Metro Detroit
I have a 79 Monte I checked and its inverted flare.
Yes lookin to do the pressure side.
houston_t
146
108
Metro Detroit
Just stumbled across these incase there is anyone else is looking. I will report back if they worked or not.
ELCAM
1,124
1,270
