That is awesome.
I just dont like cutting things that dont need to be
the wiring for the windows was brittle anyway and it's not the end of life if you cut the wires and want to revert back, you just get a new harness
That is awesome.
The Window Turbo also adds speed to my power sunroof just by installing it for my power windows.That is awesome.
I would still like to see it in a video and compare the speed to mine
Then prove it.I don't want to brag but I did build a Window Turbo eater....
Then prove it.
My passenger side did the same thing with the engine off, it would struggle to go up and stop about an inch from the top.it depends on how slow the windows were to start off with, my passanger window would never make it up with the engine off but makes it great with the relays I added. I don't know if the window motor is getting old or if the wiring is so old the power gets lost on the way the motor.
Hers mine
Pay no attention to the crazy cat that hangs around in my yard
So do you have the Window Turbo or the Window Racer that GbodyParts sells?Hers mine
