PROJECT: Fade II Black - Salon GT
My GN ran 13.90s box stock on little factory 215/65/15 eagle gts. I always wanted to do big brakes up front and if I do another car I will. But I needed to go faster before I could justify the expense. 18s still fit the body lines well, fit hugh brakes, and still has tire options for straight line traction.
Well guys, I actually got a call from the bodyshop today. I got to pick the frame up today instead of Wednesday. He was on the ball. I did stop at the car wash before I got home and sprayed the frame and hit it with some degreaser. I aslo sprayed in the frame rails, a lil dirt/mud came and a walnut but that was it. LOL. I guess I'll post a few pics:
Next on the to-do list is to dismantle front suspension and rear-end to get ready to go to the blaster hopefully this week or early next week, depending on how busy he is.
88hurstolds said:
Notch the frame and brace the lower control arm mounts while your at it
Probably won't do a notch but I have thought about the extra bracing. I will be getting the UMI control arm braces, but you were talking about the weld in braces weren't you?
Nice progress! Keep up the good work!
Thanks guys, I almost have the suspension removed so it can be stripped and coated. I have a bolt stuck in the drivers side front, lower a-arm. The bolt is seized in the bushing, guess I'll have to cut the bolt or something. It's coming along but not like I want it too, some progress is better than none though. Keep the feedback coming.
I have a lil bit of an update as of this past Friday. I finally got to dyno the heart for my Salon GT. It's a 327 sbc bored .040 over, forged crank, balanced rotating assembly, mildly worked 062 vortecs(also machined for higher lift), Lunati VooDoo 268 cam,lifters, and roller rockers. It also has a Weiand version of an Air-Gap intake with a QFT-650 DP sitting on top of it.Here's a few pics and a dyno vid. I'm happy with the results, tell me what you guys think:
360.7 hp @ 5500 rpm
361.3 tq @ 4800 rpm It should be a fun driver with 4.11's and a t5
Click below to watch the video
Looking forward to hearing your comments.
Should be great sounding lil cruiser! How tall is the OD on that trans?
