The grilles bolt to a metal plate that in turn bolts to the top of the header panel from the back. They use special bolts for the fiberglass which you will need to get from another Cutlass if you don't have them. There are also brackets by the headlights that limit their movement. If you fail to install them, the grilles will break off.
