Since it was out installed the Jeep universal end steering shaft, so much tighter now.
There is minor play in the lower bearing on the steering column but will live with it "for now"
In a case of "while you are in there" , my Fbody 36mm hollow bar with custom end links is installed.
Can't have a front bar without a rear bar so installed that too.
Does anyone know if anyone made a 26mm rear bar?
My 1 inch wrench would not slip over it anywhere but 1 1/16 had play. 1 1/32=26mm?
I'll call it 1 inch for now.
Next body mounts, arrrgh.
