Spent an hour and a half tonight bleeding the clutch. Made zero progress. Frustrated to say the least. Every time I started to get a little pedal, it went away and I ended up with nothing. Tried vacuum bleeding, pump, open bleeder, close, release pedal. Also tried open bleeder, push pedal, close bleeder, release pedal. Even tried using vacuum thru the hose in the resvoir that Perfection on YouTube recommended. Actually fot a bunch of air out and had a little pedal. Bled it normally and ended up with nothing, even worse than I started with.
