Worked on it tonight. My wife helped bleed the brakes. Still have a little air but I'll get a friend to help me. Zip tied the O2 sensor wiring out of the way, tightened a loose motor mount bolt I had forgot about, changed the transmission fluid. Hooked up the tachometer, connected the reverse light switch wiring, rinsed it off quick and went for a quick drive down to the gas station. Topped it off with non-ethanol and then let her eat.
Damn! 2nd gear always lights the tires up. Chirps into third, pulls to about 6500 rpm. Next thing I know, I'm turning 4k rpm in fifth gear. Now mind you, the speedo isn't working, but doing the math, that means I was hauling a$$. Uh oh. That's not a smart idea on public roads. I was not expecting it to be as smooth as it is. Still need to mount the ecm, fix the floor, mount the console, change the water out for coolant, and change the oil and filter. Oh and get it inspected. LOL
