For CDunigan1981, The board and jack placed under the oil pan is a method, I would not personally suggest. The why comes in two reasons, the first being that jacking on the oil pan, even with the board there, can cause the bottom of the pan to cave in. Too much cave and you lose the clearance between the oil pump pickup and the bottom of the pan, which can ultimately result in a very unhappy and blown up motor. The other point is that lifting the motor to drop the pipes while offering some advantage, isn't, strictly speaking, absolutely necessary in a lot of cases. Case in point, both Flowmasters are supposed to be installed from underneath. Instead of lifting the motor, you lift the whole car. With a set of 5ton floor stands, it only took about 3 teeth showing on the jack leg to get enough room between the car and the ground to easily slide the pipes in and rotate them up and into position. Total bummer that they didn't fit but the installation method worked like a charm. As for the Hedman's they suggest that one can go in from above and the other has to go in from underneath. Will see how that works when the time comes; it has been accurate in the past. If you are stuck with the board and jack routine, then as soon as you get the mounting bolts for the front motor mounts out and the engine high enough, then jam a short chunk of 2x4 in between the mounting ears on the engine clam, so the piece of wood sits on the frame shell, and then let the motor come down gently so the engine mounts rest on the wood instead of bedding back in. This should give you enough height to wriggle around in. As a caution, I would back off the transmission mount bolt, not remove it, just back it out a few turns. This gives the motor a little more room to rise without losing any alignment that you have.
