Decided to keep the sedan for now.
Replaced the water pump in my brother's '36. Went with a Corvette unit due to it's cleaner heater outlet pipes.
I'm in swap meet prep mode right now. Going through the shop and liquidating everything that has no specific purpose. Tore down the LT1, cleaned, painted and reassembled. Still need to come up with an oil filter adapter and do the harness.
Then pulled the 400 out of the El Camino and did the same. Tore it down, cleaned it up, replaced the rear main seal and rear cam plug that was seeping, repainted, replaced the cracked oil pan.
Bearings look great! Engine has about 5000 miles since it was built back in '09.
Still need to clean the intake manifold before I finish putting it together.
Also acquired this little generator. It was a runner when it was last used but now has no spark. Probably not a tough fix when I get around to it. Might be handy for camping and such.
