PVC Question
79MaliCrazz
577
70
Lake Wylie,SC
Can I use 2 PVC valve 1 on each valve cover if so whats the benefit of using 2 vs 1 pvc and a air breather.
20,397
with 2 you are doubling the crankcase fumes that is mixed with the a/f mixture.....1 + 1 = 2...... :popcorn:
9,619
12,705
Use one PCV on one side and a breather or hose going to the air filter on the other valve cover, you need to pull filtered air in to carry vapors and moisture through the engine to the combustion chamber to burn.
If you feel you have too much crankcase pressure then install a header evac system or a vacuum pump.
GuysMonteSS
1,449
1,542
Kentville,Nova Scotia,Canada
