Pypes, Jegs, Summit, which one?? 1/16/20
Pretty sure I've read more than a few times about people messaging Pypes asking for 3" with side exits and getting the same answer. Great customer service... 🙄
They have the best customer service. Called about the passenger side 2.5" tail pipes not fitting in both strait tail kits Summit sent me, had me send both pipes to look them over, acknowledged those two & all the others they had in house all didn't fit, sent me back the two "best" shaped tails they had & told me to have a muffler shop rebend them to fit! They had no plans at the time to correct the QA on the bending of that pipe. But to note the drivers side fit perfectly.
Sounds like extremely crappy service unless they paid for everything
I got the SS header back pypes kit for only $200 off a hot rod shop on eBay. I’ll try to remember the name but I though it was a steal. 2.5” side exit
Dang that's cheap!
no inflation
just terrible memory TURNA
Reactions: TURNA
Based on using the Pypes 2.5" side exit kit on my Dad's El Camino (fit great!), I bought the 3" kit for my Malibu.
I too was very frustrated with Pypes about not offering a side exit 3" x-pipe kit. They DO offer the side exit in cat back, but not for headers. So stupid. I emailed, called, and talked to several people and they just wouldn't do it. I even tried to by the 3" side exit tailpipes and they said they ONLY sell complete kits and wouldn't do it. Every time i have seen a car with the Hooker 3" side exit kit I wish I had ponies up the extra cash.
On top of all that, the 3" kit fits like crapola compared to the 2.5" kit. The issue is getting the pipes to tuck up into the driveshaft tunnel so they don't hang low. The X pipe is too wide to the rear so they hit the frickin floor boards. The rear of the X needs to be a tighter angle so the mid pipes could be closer together and the pipes would fit up into the driveshaft tunnel better. You can see in the pics how I shortened one midpipe, which drew it a little closer to the tunnel but no nearly enough. It also didn't leave enough room for the band clamp. I'd recommend the narrower band clamps with this kit.
I really wanted 3" even though I knew I didn't need it. It does sound really good though. In the end, I would either go with the 2.5" side exit or pony up and get the 3" Hooker kit if you want side exit. I cut mine off at a slash under the bumper.
