Those screws should be the "Double D" type. They make a 1/4" drive socket that fits them. In a pinch a secondary hanger can have it's end ground down and the shaft will fit the DD. They used those carbs on 350's too. Some had an electric hot-soak lean-out solenoid in the spot where the CCC carbs used the mixture solenoid. As Steve said, if you can't find the exact float setting 1/4" works most of the time.
